PSA Schematique 07H (2007)
Discussion in 'Citroen - Peugeot Wiring Diagram' started by Johnny, .
    It contains all the basic wiring, block diagrams, wiring diagrams and location of the circuit elements, purpose and location of fuses and connectors pinouts company cars. Also in the program PSA schematique 07H (2007) can be decoded by an electronic control unit or Twin wire his appointment.
    I recommend to download the image recorded on a DVD disc and install it.
    The key installation in the file "Readme".
    When you enter key can slow down a little bit, that's fine.
    In the same window, leave all three "birds".
    Not put quickly, so leave it alone dispatcher tasks. After installing java label can be removed as unnecessary.
    Opens in a browser, it is better to put the "Opera" as the default zoom in on a smaller step. To do this, click on the label "start schematiqe" Right, the creation of the installation, select "properties" and look for the object (the button "file location"), this is usually C: \ App \ schematique \ server \ bin. There is a file browser called Internet loading and set the default "Opera". (right click / open with ... / .... select the program / select "About" and check the box to "Use selected for all types of file.) Then, the" Opera can not open the page. Close it and start with a shortcut. Select the language, etc.
    Tested on Win XP and 7 32bit.
    "Features" installation: Look at the size of the directory C: \ APP \ schematique \ on the disc if it is not big (must be more than 4 gig), then extract the files from the directory on the CD \ Install \ Data \ *. Jar to the directory \ APP \ schematique \ disk space. The installation file is not always fully why that decompresses the data on the hard disk.
    alexx likes this.
  2. alexx
    alexx New Member
    [quote = "Johnny, сообщение: 159, участник: 2"]
    [ПРИКЛЮЧИТЬ] 105 [/ ПРИКЛЮЧИТЬ]​
    Он содержит всю основную проводку, структурные схемы, схемы подключения и расположение элементов схемы, назначение и расположение предохранителей и распиновку разъемов служебных автомобилей. Также в программе PSA schematique 07H (2007) может быть декодирован электронный блок управления или сдвоенный провод по его назначению.
    Рекомендую скачать образ, записанный на DVD диск, и установить его.
    Ключ установки в файле "Readme".
    При вводе клавиша может немного подтормаживать, это нормально.
    В этом же окне оставьте всех трех «птичек».
    Не ставьте быстро, поэтому оставьте диспетчерские задачи в покое. После установки java ярлык можно убрать за ненадобностью.
    Открывается в браузере, лучше поставить "Оперу" как по умолчанию увеличить на меньший шаг. Для этого нажмите на ярлык «start schematiqe» Справа, создание установки, выберите «свойства» и найдите объект (кнопка «расположение файла»), обычно это C: \ App \ schematique \ server \ bin. Есть файловый браузер, который называется Интернет-загрузка и установлен по умолчанию «Опера». (щелкните правой кнопкой мыши / откройте с помощью ... / .... выберите программу / выберите "О программе" и установите флажок "Использовать выбранные для всех типов файлов.) Затем" Opera не может открыть страницу. Закройте его и начните с ярлыка. Выберите язык и т. Д.
    Проверено на Win XP и 7 32bit.
    «Возможности» установки: посмотрите размер каталога C: \ APP \ schematique \ на диске, если он небольшой (должен быть больше 4 гигов), затем извлеките файлы из каталога на компакт-диске \ Install \ Data \ *. Jar в каталог \ APP \ schematique \ disk space. Установочный файл не всегда полностью, поэтому распаковывает данные на жестком диске.
    *** Скрытый текст ***​
    [/ quote]
  3. alexx
    alexx New Member
    Всем привет, очень нужен каталог, а без сообщения не показывает скрытый текст.
