Immo Universal Decoding 3.2 Full
Discussion in 'Other Automotive Software' started by derseka, .
  1. derseka
    derseka Member
    Immo Universal Decoding 3.2 remove the IMMO code of ECU
    https://mega.nz/file/zzQVkTrR#o5mWXpOmMcJiGWxe9bAWe0DHgyKLbEm-tN8J_tKQfIU
    IMMO Universal Decoding, is the best software to remove the IMMO code of ECU. The software IMMO Universal Decoding is compatible with read file with programmer such as UPA-USB, WELLON Series VP/GP, Galep, Serial and many other (not supplied with the software). Once loaded the read file of the ECU, The software will repair the IMMO code. For many ECU, there is the possibility to make virgin the IMMO in order to recode, according to the value of original key, or to delete definitively
