Year / Date of Issue: 2017-08
Version: v6.0.8.22
MAN Mantis EPC u568 2017-08 spare parts catalog contains spare parts for trucks, tractors, MAN buses, MAN engines.
In the new version of the program allows you to enter a full VIN machine for identification, but determines by VIN only the model and release date. There is a search for a picture of the original part number and a list of cars where the part was used, as well as replaced parts numbers, both new and old. To find the parts of a particular vehicle, you need to know the VIN or know exactly the model, the wheel formula, the distance between the axles, the type of suspension and cabin, and the type and modification of the engine installed on the machine. The VIN search in the program is implemented as follows. You can enter a full VIN or use VIN symbols from 4 to 6 to determine the type (up to five characters to enter zero) and 7 to 10 characters to determine the chassis number, you can also select the chassis type and number from the list of possible options. All other data points need to be searched directly on the machine.
The abbreviation MAN - means, machine-building plants Augsburg and Nuremberg. The company "MAN" was founded in 1915 and is one of the largest manufacturers of vehicles, including buses, as well as components for their assembly (bridges, gear boxes, engines, cabs).
Version: v6.0.8.22
