parts catalog spare parts for trucks, tractors, buses Man, MAN engines.
The new version MAN Mantis EPC Update 530 (2015) allows you to enter complete VIN on the vehicle identification, but defines by VIN only model and the release date. There is a search pattern for the original part number and a list of vehicles, where the item was used, and also replaced numbers of details, both new and old. To search for a specific machine parts necessary to know VIN or know exactly what model, axle, axle spacing, type of suspension and the cab, and the type and modification of the engine installed on the machine. Search by VIN in the program is implemented as follows. You can enter full VIN or use 4 to 6 symbols VIN to determine the type (up to five characters to enter zero) and from 7 to 10 characters to determine the chassis number, you can also select the type and the chassis number from the list of options. All other data indicate require search directly on the machine.
Abbreviation MAN - means Machine-Building Plants Augsburg and Nuremberg. Firm "MAN" was founded in 1915 and is one of the largest manufacturers of vehicles, including buses and also components for their assembly (axles, transmissions, engines, cabins).
