derseka
Member
PCMFlash Dongle Manager is a third-party Windows profile manager and launcher for three bundled legacy PCMFlash environments.
No physical Guardant USB dongle is connected in this workflow.
The manager creates a local virtual Guardant device through USB/IP on the same computer,
connects the selected profile and launches the matching PCMFlash build
If anyone didn’t understand: you do not need to buy any USB dongles.
Everything is already built into the manager, and it emulates all three versions that are normally sold together with Scanmatik.
All you need is a bare Scanmatik interface without any dongles.
67-in-1 profile — PCMFlash 1.2.0 — 67 enabled modules — 480 displayed ECU/TCU entries.
14-in-1 profile — PCMFlash 1.2.1 — 14 enabled modules — 124 displayed ECU/TCU entries.
11-in-1 profile — PCMFlash 1.2.1 — 11 enabled modules — 126 displayed ECU/TCU entries.
Compatible J2534 interface, such as an appropriate Scanmatik device, is still required for ECU/TCU communication.
OBD, Bench or Boot work may also require the correct cable, breakout adapter, pinout and regulated power supply
